Introdução
This iconic school calculator really needed to be torn apart.
O que você precisa
Put the tweezers (in their closed state) into the indentations on the side of the calculator.
Slowly open the tweezers, to split the calculator into two halves.
Use a pair of tweezers to pull the connector out of its holder.
Use a screwdriver to lever the connector out of its housing.
Insert a spudger in between the PCB and the rubber button holder.
Carefully remove the PCB and make sure not to damage the LCD ribbon cable.
Peel off the rubber button holder starting in the top left corner.
Back part of the case.
Front face of the case.
PCB with LCD and battery terminals.
Rubber button holder.
Buttons.
10 outras pessoas executaram este guia.
Um comentário
I veganlover loved this guide although it isn’t vegan enough.
