Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Casio Watch, use o nosso manual de serviço.
  1. Casio Digital Watch Teardown, Casio Digital Watch: passo 1, imagem 1 %32
    • This is a teardown of a Casio Digital Watch down to the internal circuitry.
    • You will need a small Phillips screwdriver for this teardown.
  2. Casio Digital Watch Teardown, Remove the Case: passo 2, imagem 1 %32
    • Carefully remove the four screws on the backside of the watch.
    • You will need an extremely small screwdriver. A screwdriver to repair glasses would work.
  3. Casio Digital Watch Teardown, Gently Push out the Screen: passo 3, imagem 1 %32 Casio Digital Watch Teardown, Gently Push out the Screen: passo 3, imagem 2 %32
    • Press your fingers on the screen and remove the watch from its case.
    • Be sure to save the three buttons that control the watch
  4. Casio Digital Watch Teardown, Remove the Battery Holder: passo 4, imagem 1 %32 Casio Digital Watch Teardown, Remove the Battery Holder: passo 4, imagem 2 %32 Casio Digital Watch Teardown, Remove the Battery Holder: passo 4, imagem 3 %32
    • Remove the Battery Holder surrounding the circuitry of the watch by carefully pulling off each of the four clips.
  5. Casio Digital Watch Teardown, Remove the Battery: passo 5, imagem 1 %32
    • Remove the battery by pulling from the sides to unstick the adhesive.
  6. Casio Digital Watch Teardown, Detach the LCD: passo 6, imagem 1 %32 Casio Digital Watch Teardown, Detach the LCD: passo 6, imagem 2 %32
    • Remove the four plastic pins connecting the LCD and remove the LCD holder
  7. Casio Digital Watch Teardown, Teardown Complete: passo 7, imagem 1 %32
    • This reveals the internal circuitry of the watch, and the teardown is complete.
Cooper
Membro desde: 02/24/15
457 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 24-6, Green Winter 2015 Membro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
Membros da 4
Autoria de 15 guias
2 comentários
This is my Casio 5 alarm tear down. Can u tell me if this has anything on it that u guys didn't do. Please email me at dolphinzpride@gmail.com...
https://linksharing.samsungcloud.com/wQ5...
Skylar Miller - Responder
I have casio illuminator dual time watch, it was damaged outerward accidentally , but internal systems r safe. But now its digits r not displaying properly, sometimes digit parts r missing n sometimes fully 888888 r shown
Sarabjeet Singh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 107
Duração total: 13,036
