Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Canon PowerShot N, use o nosso manual de serviço.
  1. Canon PowerShot N Teardown, Canon PowerShot N Teardown: passo 1, imagem 1 %32
    • Locate battery housing cover.
  2. Canon PowerShot N Teardown: passo 2, imagem 1 %32
    • Place finger on the textured portion of battery housing cover and slide cover in the direction indicated.
  3. Canon PowerShot N Teardown: passo 3, imagem 1 %32
    • Find beige tab and push it away from the battery.
  4. Canon PowerShot N Teardown: passo 4, imagem 1 %32 Canon PowerShot N Teardown: passo 4, imagem 2 %32
    • Remove battery from battery slot with fingers.
  5. Canon PowerShot N Teardown: passo 5, imagem 1 %32
    • Using a PH000 size screwdriver, unscrew four screws beneath screen.
  6. Canon PowerShot N Teardown: passo 6, imagem 1 %32
    • Remove 2 screws on the bottom of the camera.
  7. Canon PowerShot N Teardown: passo 7, imagem 1 %32
    • Remove 2 screws from the side of the camera with the on and off buttons.
  8. Canon PowerShot N Teardown: passo 8, imagem 1 %32
    • Remove the back plate.
  9. Canon PowerShot N Teardown: passo 9, imagem 1 %32
    • Locate 2 screws on “on/off” side of the camera and unscrew them.
  10. Canon PowerShot N Teardown: passo 10, imagem 1 %32
    • Locate 2 screws on the other side of the camera and remove them.
  11. Canon PowerShot N Teardown: passo 11, imagem 1 %32
    • Remove one screw from the bottom of the camera.
  12. Canon PowerShot N Teardown: passo 12, imagem 1 %32
    • Remove front plate from motherboard so that one ribbon cable is exposed.
  13. Canon PowerShot N Teardown: passo 13, imagem 1 %32
    • Locate the second ribbon cable.
  14. Canon PowerShot N Teardown: passo 14, imagem 1 %32 Canon PowerShot N Teardown: passo 14, imagem 2 %32
    • Using plastic spudger, push tab to release the ribbon cable.
  15. Canon PowerShot N Teardown: passo 15, imagem 1 %32
    • Locate screw under released ribbon cable and remove it.
  16. Canon PowerShot N Teardown: passo 16, imagem 1 %32 Canon PowerShot N Teardown: passo 16, imagem 2 %32 Canon PowerShot N Teardown: passo 16, imagem 3 %32
    • With the camera lens facing you, remove 4 screws around the lens.
  17. Canon PowerShot N Teardown: passo 17, imagem 1 %32
    • Flip over and remove 1 screw from side with playback/phone options .
  18. Canon PowerShot N Teardown: passo 18, imagem 1 %32 Canon PowerShot N Teardown: passo 18, imagem 2 %32 Canon PowerShot N Teardown: passo 18, imagem 3 %32
    • Unscrew 2 screws from top, bottom, and both sides of screen.
    • Pull off white cap which edges the screen.
  19. Canon PowerShot N Teardown: passo 20, imagem 1 %32 Canon PowerShot N Teardown: passo 20, imagem 2 %32
    • Remove white metal plate behind screen (tip: try not to bend).
  20. Canon PowerShot N Teardown: passo 21, imagem 1 %32 Canon PowerShot N Teardown: passo 21, imagem 2 %32
    • Push out LCD screen.
Jack Graver
Membro desde: 03/04/16
313 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 6-5, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-5, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G5
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 20
Duração total: 1,305
