Documento em destaque
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Autosampler Node, use o nosso manual de serviço.
  1. Generally, there will also be ultrasonic components, such as wires, present within the node. There is no ultrasonic connected to our node in order to focus entirely on the autosampler
    • Generally, there will also be ultrasonic components, such as wires, present within the node. There is no ultrasonic connected to our node in order to focus entirely on the autosampler
  2. Ensure you remove the battery first before doing anything else
    • Ensure you remove the battery first before doing anything else
    • If you choose to disconnect the wires from the terminal, we recommend you either write down the wires' respective locations on the terminal, or consult our pin documentation when reassembling
    • To disconnect the blue circled point on the solar charger, you have to remove the terminal at the blue circle on the board
    • Pull the module from the bottom; pulling the module in a different way may damage it
    • In the second image, one of the screws is already removed
    • With the interior of the small node removed, these are the components you should have (from left to right)
      • The battery
      • Solar charger with terminal still attached
      • Relay with terminal still attached
      • Module with antenna still attached
      • Board with 4 screws
Documentos anexados
Nicholas Jeng
529 reputação
3 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 101
