Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Asus ZenWatch 3, use o nosso manual de serviço.
  1. Asus ZenWatch 3 Teardown, Let's begin: passo 1, imagem 1 %32
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: passo 2, imagem 1 %32 Asus ZenWatch 3 Teardown, Band Removal: passo 2, imagem 2 %32
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: passo 3, imagem 1 %32
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: passo 4, imagem 1 %32
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: passo 5, imagem 1 %32
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: passo 6, imagem 1 %32
    • Battery
  7. Asus ZenWatch 3 Teardown: passo 7, imagem 1 %32
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: passo 8, imagem 1 %32
    • Complete disassembly
Reon
Membro desde: 02/01/13
141 Reputação
Autoria de 1 guia
20 comentários
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Responder
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Responder
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Responder
What should I do if the power button doesn’t work?
MichaelKing10or - Responder
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 43
Duração total: 14,456
