Ir para o conteúdo principal
Este teardown está em andamento – Atualizar periodicamente para ver as últimas alterações!
O que você precisa
Vídeo de Apresentação
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: passo 1, imagem 1 %32 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: passo 1, imagem 2 %32 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: passo 1, imagem 3 %32
    • The back panel is removed.
    • The SSD is removed.
IT FIX
Membro desde: 10/16/17
6.340 Reputação
Autoria de 74 guias
12 comentários
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - Responder
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - Responder
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - Responder
It’s very easy but it’s supports only M.2 SSDs
IT FIX - Responder
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 25
Duração total: 6,434
