Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Asus Chromebit CS10, use o nosso manual de serviço.
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: passo 1, imagem 1 %32 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: passo 1, imagem 2 %32 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: passo 1, imagem 3 %32
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
dragon788
Membro desde: 08/20/16
708 Reputação
Autoria de 3 guias
Equipe
ComputerPhreaks Membro de ComputerPhreaks
Business
1 Membro
Autoria de 3 guias
2 comentários
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - Responder
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 60
Duração total: 1,641
