Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Arlo Pro 3 - 2K QHD Wire-Free Security Camera, use o nosso manual de serviço.
  1. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown, Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 1, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown, Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 1, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown, Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 1, imagem 3 %32
    • Features:
    • 2K Video with HRD
    • Color Night Vision
    • Integrated Spotlight
    • 2-Way Audio
    • Weather Resistant
    • In the Box:
    • Camera, Battery Pack, USB Charging Cable, and Magnetic Mounting Base
  2. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 2, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 2, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 2, imagem 3 %32
    • To open the Arlo Pro 3 Camera, press the Button on the bottom, and pull the Camera Face (Camera Body) away from the Camera Enclosure
    • Charging port for internal battery pack
  3. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 3, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 3, imagem 2 %32
    • Remove the Battery from the Camera Body by gently pulling the Battery away from the Camera Body
    • The Battery Capacity is 4800mAh
  4. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 4, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 4, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 4, imagem 3 %32
    • To remove the Camera Face Plate from the Camera Body, remove the four PH00 screws in the Battery Compartment area that secure the Camera Face Plate to the Camera Body
    • Use the Spudger Tool to pop off the Camera Faceplate
  5. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 5, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 5, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 5, imagem 3 %32
  6. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 6, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 6, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 6, imagem 3 %32
    • The small PCB behind the camera face plate contains Sensors, LED lighting components, and Infrared Lighting LEDs. This PCB is held in place with three PH00 screws
    • Remove these screws to remove the PCB
    • Use a Spudger Tool to pry the PCB loose
  7. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 7, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 7, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 7, imagem 3 %32
    • The microphone on the PCB is held in place with a rubber gasket, and connected via flex cable
    • To remove the Microphone, use a Spudger Tool to flip up the retention clip that holds the flex cable in place, and gently pop the microphone gasket from the PCB
    • The microphone rubber gasket can be separated from the Microphone
    • The Microphone is a Vesper VM1010 Wake-On-Sound MEMS Microphone
  8. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 8, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 8, imagem 2 %32
    • With the PCB removed in the previous steps, use the Spudger Tool to pry the Camera face from the Camera Body
    • Pull the Camera face away from the Camera Body
  9. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 9, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 9, imagem 2 %32
    • There are two more PCBs in the camera face assembly. The Top PCB is held in place via a zero force insertion connector.
    • A Spudger Tool can be used to remove the Top PCB by gently prying the Top PCB loose near the zero force insertion connector, and working around the outside of the Top PCB prying it loose further with the Spudger Tool
    • The Siren/Speaker is also connected to the Top PCB and can be unplugged.
  10. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 10, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 10, imagem 2 %32
    • The Top PCB has a Heatsink on it that can be removed with a Spudger or Dental Pick Tool
    • The Heatsink is held in place with Thermally Conductive Adhesive Transfer Tape
  11. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 11, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 11, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 11, imagem 3 %32
    • Once the Heatsink has been removed, the Top PCB can be inspected. The Top PCB has RF Shielding on both sides
    • The RF Shielding can be removed using a Dental Pick Took
    • Pro-tip, if the RF shielding has a small circle indention on it, there is a good chance the shield was snapped in place, and not soldered to the PCB, which makes it easier to remove
  12. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 12, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 12, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 12, imagem 3 %32
    • One side of the Top PCB appears to be Power and Audio. Three components were crossed on this PCB. One Part was located up under the RF shielding Frame
    • BQ25898 - I2C Controlled Single Cell 4-A Fast Charger with MaxChargeTM for High Input
    • TAS2560 - 5.6W Class-D Mono Audio Amplifier with IV Sense
    • DSP Group D2A3X - Audio DSP
  13. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 13, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 13, imagem 2 %32
    • The other side of the Top PCB has the Camera Video Image Processor, RAM, FLASH, and Wireless Communications
    • These components are covered in Thermally Conductive Adhesive Transfer Tape, which can be removed with a Dental Pick Tool
  14. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 14, imagem 1 %32
  15. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 15, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 15, imagem 2 %32
    • Turning our attention to the other board in the Camera Face, we see that it is held in place with three PH00 Screws
    • To remove this PCB, remove the three PH00, remove the heatsink, and then pull out the PCB
  16. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 16, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 16, imagem 2 %32
    • Looking at this PCB, we see one side has a heatsink, and the other side has the Camera Lens, Camera Image Sensor, and PIR Motion detector
  17. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 17, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 17, imagem 2 %32
    • Using a Dental Pick Tool, remove the heatsink.
    • The heatsink is for the PYD1548/7660 Excelites Tech Low Power Motion PIR Sensor. PIR Sensors can be kept cool to improve sensing performance
    • Other components on this side of the board appear to be for power and control functions
  18. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 18, imagem 1 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 18, imagem 2 %32 Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 18, imagem 3 %32
    • On this side of the PCB, there are two PH00 screws that hold the Camera Lens in place. Remove these screws to release the Camera Lens
    • The Camera Lens is motorized. There is a control wire and connector for the Camera Lens. Remove the Camera Lens wire from the connector, and pull the Camera Lens free to reveal the 2K QHD Camera Sensor
    • Components:
    • 2K QHD Camera Sensor - Not marked
    • PYD1548/7660 Excelites Tech Low Power Motion PIR Sensor
  19. Arlo Pro 3 - 2K QHD Wire-Free Security Camera Teardown: passo 19, imagem 1 %32
    • Teardown Exploded View
    • Arlo Pro 3 2K QHD Wire-Free Security Camera
Robert Shuler
Membro desde: 03/12/19
3.539 Reputação
Autoria de 11 guias
2 comentários
Hi strange question but i have Alro pro 3 cameras that have 7 day rolling cloud space. I also have an arlo 4 bought not knowing that it did not include the cloud space. Was wondering how the 4 and the 3 compare and can one build a 3 from the 4?
Andrew - Responder
My camera fell like 15 feet onto concrete. Now it powers on and syncs, but will no longer actually connect. What most likely broke inside? Thanks
Luke Urice - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 112
Duração total: 6,029
