Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Anker LC-90 Rechargeable Flashlight, use o nosso manual de serviço.
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: passo 1, imagem 1 %32 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: passo 1, imagem 2 %32 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: passo 1, imagem 3 %32
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: passo 2, imagem 1 %32
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: passo 3, imagem 1 %32 Anker LC-90 Rechargeable Flashlight Teardown: passo 3, imagem 2 %32 Anker LC-90 Rechargeable Flashlight Teardown: passo 3, imagem 3 %32
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: passo 4, imagem 1 %32
    • The Anker LC-90 is now tore down
Nick Wolfe
Membro desde: 01/24/18
721 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G4, Livingston Winter 2018 Membro de Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Membros
Autoria de 18 guias
5 comentários
cannot buy parts or return
JULIA - Responder
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
JULIA - Responder
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - Responder
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - Responder
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 40
Últimos 30 dias: 144
Ao todo: 4,684
