Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua American Era Electric Rice Cooker, use o nosso manual de serviço.
  1. American Era Electric Rice Cooker Teardown, Rice Cooker Teardown: passo 1, imagem 1 %32
    • Start with the rice cooker unplugged, on a flat surface.
  2. American Era Electric Rice Cooker Teardown, Remove Pot and Lid: passo 2, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: passo 2, imagem 2 %32 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: passo 2, imagem 3 %32
    • Remove the lit and pot and turn upside down.
  3. American Era Electric Rice Cooker Teardown, Remove Bottom Plate: passo 3, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: passo 3, imagem 2 %32 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: passo 3, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Remove the bottom plate by lifting one of the rubber feet.
  4. American Era Electric Rice Cooker Teardown, Remove Internal Screws: passo 4, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Internal Screws: passo 4, imagem 2 %32
    • We're inside! Here's our first look at the circuitry. Let's take it apart.
    • Use a 3/8" or 8 mm flathead screwdriver to remove these six screws.
  5. American Era Electric Rice Cooker Teardown, Bend Tab: passo 5, imagem 1 %32 American Era Electric Rice Cooker Teardown, Bend Tab: passo 5, imagem 2 %32
    • Find the metal tab that connects the center button to the switch lever.
    • Use pliers to bend the metal tab into a U shape.
    • Align the tab with the slot so that it falls through.
  6. American Era Electric Rice Cooker Teardown, Remove Heating Element: passo 6, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Heating Element: passo 6, imagem 2 %32
    • Turn the rice cooker right-side up.
    • Grab the center button and pull the heating plate upward. The gray metal ring should come out with it.
  7. American Era Electric Rice Cooker Teardown, Remove Temp. Sensor: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the screw connecting the temperature sensor to the heating element.
    • Remove the temperature sensor.
  8. American Era Electric Rice Cooker Teardown, Remove Center Button: passo 8, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Center Button: passo 8, imagem 2 %32 American Era Electric Rice Cooker Teardown, Remove Center Button: passo 8, imagem 3 %32
    • Three bent metal tabs connect the center button to the heating element. Use pliers to flatten these three tabs.
    • Remove the center button from the heating element.
  9. American Era Electric Rice Cooker Teardown, Remove Control Panel: passo 9, imagem 1 %32 American Era Electric Rice Cooker Teardown, Remove Control Panel: passo 9, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the screw that secures the control panel.
    • Remove the control panel from the outside of the rice cooker.
  10. American Era Electric Rice Cooker Teardown, Disassemble Control Panel: passo 10, imagem 1 %32 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: passo 10, imagem 2 %32 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: passo 10, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the screw securing the rectangular fiberglass plate. This should free the two light bulbs.
    • Use a Phillips #1 screwdriver to remove two screws securing the switch lever to the control panel plate. Remove the switch lever.
  11. American Era Electric Rice Cooker Teardown, Disassemble Switch: passo 11, imagem 1 %32 American Era Electric Rice Cooker Teardown, Disassemble Switch: passo 11, imagem 2 %32
    • Use pliers or hex wrench to hold the nut while using a Phillips #1 screwdriver to remove the screw holding the switch assembly together.
    • Pull the switch assembly apart into its parts. Careful not to lose any of these small parts!
  12. American Era Electric Rice Cooker Teardown, All Done!: passo 12, imagem 1 %32
    • And here we have it: a fully disassembled rice cooker.
Travis Taylor
Membro desde: 04/12/13
464 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-40, Amido Spring 2013 Membro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
Membros da 4
Autoria de 37 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 32
Duração total: 4,079
