Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Amazon Fire Stick 4k, use o nosso manual de serviço.
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: passo 1, imagem 1 %32
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: passo 2, imagem 1 %32 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: passo 2, imagem 2 %32
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: passo 3, imagem 1 %32
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: passo 4, imagem 1 %32 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: passo 4, imagem 2 %32 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: passo 4, imagem 3 %32
    • Once the screws are removed, all the pieces come out easily.
Nathan Ruffing
Membro desde: 05/24/21
593 Reputação
Autoria de 2 guias
Um comentário
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 55
Duração total: 3,560
