Ir para o conteúdo principal
Amazon Fire HD 3rd Gen Disassembly
O que você precisa
  1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, imagem 1 %32 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, imagem 2 %32 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: passo 1, imagem 3 %32
    • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
  2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, imagem 1 %32 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, imagem 2 %32 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: passo 2, imagem 3 %32
    • Peel off the 2 yellow pieces of yellow tape on the battery.
  3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, imagem 1 %32 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, imagem 2 %32 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: passo 3, imagem 3 %32
    • Take off all the ribbon cables connected to the main board. (Marked in Red)
    • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
  4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: passo 4, imagem 1 %32
    • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
    • Then, take out the 7 screws hold in the gray bracket (yellow)
    • Now, unscrew the 8 screws holding the motherboard. (green)
  5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: passo 5, imagem 1 %32
    • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
  6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: passo 6, imagem 1 %32
    • 1. Remove the Headphone and USB ports.
    • 2. Remove motherboard.
    • 3. Remove the speakers.
    • 4. Remove gray bracket with battery.
  7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: passo 7, imagem 1 %32
    • Now, using a T4, unscrew the 4 screws holding in the screen.
  8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: passo 8, imagem 1 %32
    • Congrats! Now follow the directions in reverse to reassemble your Fire!
Linha de Chegada
3 outras pessoas executaram este guia.
Cooper Anderson
Membro desde: 09/08/17
541 Reputação
Autoria de 2 guias
Equipe
Cooper Anderson Membro de Cooper Anderson
Business
1 Membro
Autoria de 2 guias
Um comentário
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,599
