Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Amazon Echo Spot, use o nosso manual de serviço.
  1. Amazon Echo Spot Teardown, Begin: passo 1, imagem 1 %32
    • Amazon Echo Spot
  2. Amazon Echo Spot Teardown: passo 2, imagem 1 %32 Amazon Echo Spot Teardown: passo 2, imagem 2 %32
    • Remove Bottom Plate. It's a sticker, thicker than you expect. Pry hard.
    • One T8 screw prevents the screen from rotating, remove this prior to twisting the screen out. Two T5 screws hold the electronics stack.
  3. Amazon Echo Spot Teardown: passo 3, imagem 1 %32 Amazon Echo Spot Teardown: passo 3, imagem 2 %32
    • There is a Micro USB port hiding in the back under a plastic cover.
    • Attaching a USB cable to the port reveals a device that classifies itself as an "Android Device"
    • It is also possible by holding down all 3 buttons on the top to put the device into FASTBOOT mode. Lots more to explore here.
  4. Amazon Echo Spot Teardown: passo 4, imagem 1 %32
    • After removing the aforementioned T8 screw, press your palm against the screen and twist counterclockwise. Alternately, hot-glue the screen to the workbench, twist the back off, then remove the glue.
  5. Amazon Echo Spot Teardown: passo 5, imagem 1 %32
    • Disconnect Cables
  6. Amazon Echo Spot Teardown: passo 6, imagem 1 %32 Amazon Echo Spot Teardown: passo 6, imagem 2 %32
    • Display Assembly
    • Note there is a camera and what appears to be either a light or motion sensor next to the camera.
  7. Amazon Echo Spot Teardown: passo 7, imagem 1 %32 Amazon Echo Spot Teardown: passo 7, imagem 2 %32 Amazon Echo Spot Teardown: passo 7, imagem 3 %32
    • Display module is round and glued to the cover glass
  8. Amazon Echo Spot Teardown: passo 8, imagem 1 %32 Amazon Echo Spot Teardown: passo 8, imagem 2 %32
    • Logic Board
  9. Amazon Echo Spot Teardown: passo 9, imagem 1 %32 Amazon Echo Spot Teardown: passo 9, imagem 2 %32
    • Chips
    • MediaTek MT8163V - Quad ARM Cortex-A53 System on a Chip
    • GOODIX GT5668 - Touchscreen Controller
    • Cypress CYW43569 - 802.11 a/b/g/n/ac Bluetooth 4.1
    • MediaTek MT6323LGA - PMIC
    • Micron MT52L512M32D2PF-107 WT D9SSF - 16Gbit LPDDR3 SDRAM
    • SK hynix H26M41208HPR - 8GB NAND
mcwiggin
616 Reputação
Autoria de 3 guias
18 comentários
What display is being used? Rectangular or circular shape? Can you please publish article number and or manufacturer code?
Andreas - Responder
He said the display was round. I have no idea what the code would be, but I’d assume it’s a custom Amazon display.
Liam Powell -
Thanks for doing this. Any photos of the speaker system? The sound is pretty good for such a small device.
Martin P - Responder
Any photo of the power-plug? (+ in center?) Specification of the power adapter?
Gorm Næss - Responder
What display is being used? Can you please publish article number and or manufacturer code?
It seems that display is octogonal shape, not circular.
OLED or LCD panel ??
Daniel Fernandez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 50
Duração total: 18,952
