Introdução
Amazon's Echo line is expanding—or in the Dot's case, shrinking! The new hockey-puck-sized Echo Dot lets you add some Alexa-infused personality to your existing home speaker setup. We're eager to try it, but not before we've thoroughly taken it apart. Alexa, brace yourself—it's teardown time.
If you're curious about the innards of the other Echos, we've got teardowns of the original Echo and the Amazon Tap as well.
Teardowning is what we do! Follow us on Instagram, Twitter, and Facebook for all the latest repair news.
O que você precisa
If Amazon ever ventures into the canned tuna fish business, they'll have a great package design ready to go. In the meantime, the Dot contains some tasty morsels:
Dual-band, dual-antenna 802.11 a/g/b/n Wi-Fi with MIMO
Alexa Voice Search
7-microphone array
Light ring volume adjustment
Bluetooth 4.0 for sending and receiving audio
3.5 mm audio output for external speakers
Topside, the Dot looks exactly like its older brother, the Echo, complete with its action and mic mute buttons, light ring, volume ring, and microphone array.
Things are a little different down below, where we're greeted by a rubber cover and some labeling—and not much else.
Amazon bestows the Dot with a new model number: S04WQR.
For a more exacting visual comparison, we dug up an original Echo.
And by "dug up," we mean we grabbed it from the corner of the teardown table, where it has been faithfully serving up groovy repair tunes ever since we reassembled it.
TL;DR: it looks like Amazon pretty much just chopped out the middle of the old Echo. Neat!
Not at first. 1st gen dots (what I searched when looking for this) have no volume dial and are held together with 4 screws. Putting the thing back together requires a large exercise in patience trying to align the 4 screw holes for everything inside and not damage the copper ribbon in the middle.
We peel away the grippy rubber pad, fully expecting to find our first screws—but instead, we're greeted by glue. Boo!
We'd like to report that the lower case simply clips in place, but when the first opening pick fails to pop it free, we insert another. And another. And another.
Yep—it's glued, too.
We wrestle it free eventually, but so far the Dot is off to a decidedly less friendly start than its older sibling.
Our first look inside reveals what sophisticated tech insiders will instantly recognize as a big metal thing.
Fortunately, this metal thing has screws! Some long T6 Torx screws are threaded through the Dot from bottom to top; our driver dispatches them forthwith.
Out tumbles the metal thing, with a small speaker riding piggyback.
Yep, it's a speaker, albeit a small one. It connects to the Dot by way of a couple pairs of spring contacts.
The speaker is lightly adhered to this shapely blob of steel, which seems to be a simple weight in the base of the Dot. It's likely designed to keep the device planted, so you can twist the volume ring without accidentally spinning your Dot across the table.
its not working
The weight is not steel. It’s most likely die-cast zinc alloy.
With the screws removed, only a thin ribbon cable ties all these layers together. Introducing Amazon Echo Dot: Accordion Edition.
We shuffle the layers of plastic and silicon back together temporarily; it's all coming apart soon enough.
After tweezing away the ribbon cable, we're ready to inspect the motherboard.
Chips on one side, ports on the other. Here's what this motherboard is packing:
Texas Instruments DM3725CUS100 Digital Media Processor
Micron MT46H64M32LFBQ 256 MB (16 Meg x 32 x 4 Banks) LPDDR SDRAM
Samsung KLM4G1FEPD-B031 4 GB High Performance eMMC NAND Flash Memory
Qualcomm Atheros QCA6234 Integrated Dual-Band 2x2 802.11n + Bluetooth 4.0 SiP
Texas Instruments TPS65910A1 Integrated Power Management IC
Texas Instruments TLV320DAC3203 Low Power Stereo Audio Codec w/ Headphone Amplifier
Texas Instruments TPA2025D1 2 W Class D Speaker Amplifier
I have a question for those out there in the know, when it comes to streaming music on the likes of Spotify Premium in high quality. My budget is admittedly limited, while trying to achieve within those limits the most satisfying, balanced and detailed sound possible. I currently have a new Audio Pro addon T10 (identical to the C10, but without Wi-Fi integration), connected via a quality auxiliary cable to the Amazon Echo Dot. The C10 was favorably compared to the new Sonos Play 5 by whatHiFi; that gives you a point of reference.
Now, when streaming Spotify at 320kbps, is the speaker sonically held back by the audio processing of the Amazon Echo Dot, whose built-in DAC is the DAC3203 by Texas Instruments, relative to a potential external DAC? If I go the external route, I want to make sure it is truly worthwhile, as the voice assistant in the Dot is unbelievably convenient for streaming music on the fly.
IC identification, continued:
Monolithic Power Systems MP2145GD 6 A synchronous step-down converter
Maxim Integrated MAX14585AEVB+ hi-speed USB analog switch
NXP Semiconductor NX3L1G3157 SPDT analog switch
Texas Instruments LP3985IM5X-3.0 150 mA / 3.0 V LDO regulator
Diodes Incorporated 74LVC1G125 single buffer
With disassembly nearly complete, we tear into the control wheel. It's a dead ringer for the one we found in the original Echo, complete with its geared encoder wheel.
That's just fine by us, since it means at least some replacements parts can likely be shared between the original Echo and the Dot.
It also means servicing instructions for one will likely be echoed by the other. All in all, it's a win for fans of repair and bad puns everywhere.
And buried in the top layer we find another control board, functionally identical to the one we dug up in the original Echo.
National Semiconductor LP55231 Programmable 9-Output LED Driver (x4)
Texas Instruments TLV320ADC3101 92dB SNR Low-Power Stereo ADC (x4)
Diodes Incorporated LMV321SE Single Operational Amplifier
Texas Instruments SN74LVC74A Dual Positive-Edge-Triggered D-Type Flip-Flops
Diodes Incorporated 74LVC1G14 Schmitt Trigger Inverter
Diodes Incorporated 74LVC1G125 Single Buffer (x2)
Amazon Echo Dot Repairability Score: 6 out of 10 (10 is the easiest to repair)
The majority of the device is held together by standard Torx screws.
Many components are common to the original Echo, making it easier to source parts.
The rubber foot, base cap, and speakers are held in place with tough adhesive.
The headphone jack and USB port, two common points of failure, are soldered directly to the motherboard.
50 comentários
Still can't figure out the microphone manufacturer?
Microphones are Knowles :: SiSonic™ Microphones http://www.knowles.com/eng/Products/SiSo...
Can we know which model exactly ? or at-least its near specifications ?
Most likely SPA1687LR5H-1 since it is connected to the ADCs differential inputs and meets the specs and the dimensions.
Johannes
does this have the same audio amp as the Echo (TI TPA3110D2)
I am trying to figure out why they did not use mems microphones with digital output and used analog ones with 4x ADCs . Wouldn't that have reduced BOM significantly ??
Looks like those ADCs are more like mini DSPs. Probably has some AGC and some FIR filtering happening in there ...
Maybe the TI DSP chip has no or few PDM interface for the MEMs microphones.
Wish it had bluetooth microphone abilities.
How would you rate its moisture-resistance? Could it survive being in the bathroom during a hot shower?
Has anyone done any serious software/hardware hacks to improve on its performance or add extra features?
Hi John
Theres a google hack....... email me brad1taylor@yahoo.co.uk
Has anyone torn down the new Echo Dot yet? Keen to see if they've upgraded anything of the innards.
I am currently Tearing down the Generation 2. I already got it opened up but wont be able to fully dissect it until next week. I can tell you already there is defiantly some notable differences but over all its very similar.
Aaron -
Thanks Aaron! Look forward to it.
Yes i have just put photo's on my facebook. You should be able to see them. https://scontent-lga3-1.xx.fbcdn.net/v/t... https://scontent-lga3-1.xx.fbcdn.net/v/t...
Has anyone noticed how where (or if) an input signal could be injected instead of microphone. Perversely, I am trying to use Alexa without a mic, and generate the voice commands from a disabled person's AAC device, rather than have to get Dot's mike to listen to AAC"s speaker. Cut out the middleman, so to speak (whoops, no pun intended!)Thanks for looking. Happy New Year, Stig.
The ADC has a digital input, you should look if it matches your output and then solder to it. Alternatively you could use the waveform coming from the output of your friend, use an opamp to create differential signals and the feed it to the same inputs like the micropohes are connected to. Be careful with the cable length though, could create a lot of noise.
On the DM3725 Media Processor is about $45 a chip and $26 in volume. Amazon could have used a BCM2837 quad processor which has a base price of $8.00 ea. Not sure how their making money selling this unit at $50 and making any profit margin. I just purchased the Echo Dot and instead of having the volume wheel they went to a plus and minus button for volume control. So now their are 4 buttons on the top of the unit.
It's possible that they're not making money on these. The quantity of data Amazon can collect from people using Alexa may make it worth only breaking even on this hardware.
In addition, it isn't unlikely that Amazon and TI have a Business-to-Business agreement allowing Amazon to get TI hardware for a unique price. TI will benefit from Amazon using this chip, because a high-profile company such as Amazon putting trust in this chip will inspire other companies to trust this chip. This will likely help TI in both sales and stock prices. Therefor, selling this chip in a MASSIVE quantity to Amazon for a lower price isn't as scary of a prospect for TI. I also agree with Evan, although I imagine they will break even at the very least on this product.
There is no way Amazon is paying $26 for the processor. The DM3725 is a single core Cortex-A8 device with a TI DSP, in a thoroughly mature 45 nm process (probably outsourced to TSMC, to boot), and I'm willing to bet the die size is still smaller than that of the 40 nm BCM2837 with its quad Cortex-A53 CPU complex, GPU, etc.
You can be certain that TI and Amazon have a direct purchase agreement as Amazon is a heavy user of TI mixed signal and power devices in their other products. Heck, anyone selling semiconductors to Amazon is doing so directly, without the need for a distributor (unless Amazon's assembly house uses a distributor for inventory management).
I'm sure TI is doing just fine selling to Amazon, although I suspect the BOM cost for the Dot is still probably such that Amazon is just covering costs with some margin built-in for resellers like Target, Best Buy, etc.
Without knowing exactly how many of these devices are coming off the production line, there is no way anyone can work out the component, or final BOM cost however the silicon is going to be significantly cheaper than the prices quoted above, moreso if there is a revolving contract in place with the supplier. The Dot gen 2 already confirms departure from rotary to push button for the controls, meaning it is no longer Echo's spare rib.
Additionally Amazon have utilised the Poundshop subconscious by pitching it (at least in the UK) at this price. You want a Dot, but to get the free shipping you have to buy something else in the store to qualify. By browsing for something else if only for a few minutes they will have seen what your search characteristics are, your credit detail/records from the checkout to see if it is regular or impulse buying and target accordingly.
I'm more interested in who has access to the voice data since it will remain on a large SSD to be dissected for every nuance, for all eternity.
What is the film tape part in the case? And what does it do? As seen on the side case in step 9
That's a ribbon cable that connects the upper assembly to the motherboard.
I was talking about the one that is sitting in the case not connected to anything as seen in step 9
This part in the case https://scontent-lga3-1.xx.fbcdn.net/v/t...
It is connected to the motherboard as shown in the second photo in step 7.
Can anyone tell me which type of switch amazon echo uses to power up? is it a push button switch or something else?
Has anyone any schemas of this Echo Dot?
Hi, if still interested in this: I’ll generate a schematic out of the microphone/LED-PCB in the next weeks, because I want to make it smaller and add some sensors as well. Mail me to “kueder (at) gmx . ch”.
Simon -
Did anyone research regarding what signals is on the "D" connection pads near of power socket (Step 8, J2 connector)?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Are these contact pads for these interfaces: UART Rx/Tx; Factory reset; SDMMC; VCC, etc.? Anybody knows?
https://i.imgur.com/EWCwaCg.png
This was correct for the amazon echo but I havent tried it on the dot, with the echo you could connect through UART and then grubhack to root it
echo dot 2.. is a downgrade in chips over echo dot 1...from wifi(Atheros QCA6234 to mediatek) , ic , processor ( 20 $ vs 7$), and the plastic is a lot cheaper..
on echo dot 1.. you feel it like metallic..and heavy
Hi, can anyone know what is the type or # number of the leds at the led ring?
Thanks
Aviv
Do you have this figured out yet? I’ve determined they are discrete RGB common cathode type parts, but have not nailed down the exact maker yet. I intend to wire them out to remote LEDs.
where do you tap into the circuit board to bring a signal out to an external DAC?
What kind of connector does it have? It doesn’t look like USB-C, which seems surprising, given that that everyone seems to want it to “take off”.
USB-C is for computers, phones and external accessories alike. This device only uses USB for power, so a C port would be too big and more costly to implement than a normal USB micro B port.
What does the WiFi antenna look like? at 2.4 / 5 ghz it would seem to require a very shore one?
has anyone been able to test what the voltage is of the LED lights?
my daughter tried the wrong headphone jack in our echo dot and a piece broke off in the hole where a jack could go. Any recommendations on how to get that out? it’s super lodged in there …..
