Ir para o conteúdo principal
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Airvape Legacy Pro, use o nosso manual de serviço.
  1. Airvape Legacy Pro Teardown, Airvape Legacy Pro Teardown: passo 1, imagem 1 %32
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Teardown, Angled look at PCB: passo 2, imagem 1 %32
    • Just another photo
  3. Airvape Legacy Pro Teardown, Under wireless charger: passo 3, imagem 1 %32
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
ShellingRook27
Membro desde: 08/21/19
1.821 Reputação
Autoria de 7 guias
Equipe
Repair For You Membro de Repair For You
Business
1 Membro
Autoria de 11 guias
4 comentários
Looking forward to seeing this continue!
andypapster - Responder
nothing more with the teardown?
seedy53 - Responder
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 111
Duração total: 593
