Introdução
It’s been two years since the first AirPods teardown, and in those two years AirPods have become both surprisingly popular and infamous for their short lifespan. These second-generation ‘pods look the same on the outside, but have a couple notable internal upgrades. The real upgrade we’ve got our hopes up for is repairability—it would be great if these didn’t end up in the landfill after a couple years of use.
Is this upgrade worth the price increase? What does the H in H1 stand for? Will these AirPods be the RepairPods evolution we are hoping for? There’s only one way to find out: with a teardown!
For even more exciting news and teardowns, follow us on Twitter, Instagram, and Facebook. For iFixit delivered, check out our newsletter.
O que você precisa
Vídeo de Apresentação
This fancy dental floss looks very familiar, but according to Apple it's worth $40 more than its predecessor. Here's the story the spec sheet tells:
Two AirPods weighing in at 0.14 oz (4 g) each, with a 1.41 oz (40 g) charging case
Each AirPod measures 0.65" × 0.71" × 1.59" (16.5 mm × 18.0 mm × 40.5 mm) while the charging case measures 1.74" × 0.84" × 2.11" (44.3 mm × 21.3 mm × 53.5 mm)
New H1 chip featuring Bluetooth 5
Wireless charging case
"Hey Siri" support
We start our examination with these curious markings on the boxes. We're seeing multiple references to something called "AirPower" ... ?
Next we X-ray the box to confirm if it's safe to open. Oh, who are we kidding—we're opening it regardless. Safety third, we always say.
While you may not think of two-year-old products as ancient, reports say these first-gen AirPods (left) are aging fast.
The new case (right) looks shinier, but that might just be due to wear on the Gen 1.
We also note a relocated pairing button, and a newly placed external LED charging indicator.
AirPower as many of your readers know is the wireless charging mat that Apple was supposed to have released by now.
What nobody talks about and what I noticed immediately is this: Why does Apple have this on the outside of the AirPods 2 box as a sticker??!! What’s underneath the sticker?
On the other end of the wireless earbud arena, we have the new Samsung Galaxy Buds—which we recently tore down and found to be surprisingly repairable! The ball is in your court, AirPods.
We have some real gripes with the AirPods' design priorities, but there's no denying the engineering talent that goes into them. Peer into this X-ray and you can pick out batteries, microphones, antennas, speaker drivers, circuit boards—all in something that fits in your ear.
Inside the flip top, we find a new model number, A1938—with the same indicated 398 mAh battery capacity for the case.
What should you do with them, then? Good question.
Okay, enough talk! On to the good stuff. Having been down this road before, we start with some heat to soften the adhesive. Does it help? Honestly ... maybe.
Next, some careful blade work.
After slicing open the buds, we give them a nice relaxing isopropyl alcohol bath in hopes that they will let their (adhesive) guards down a bit.
While the alcohol helped us get one foot in the door, we caught our tweezers in the jamb. A good firm pry opens up the driver for inspection.
Sweat beads as we make an incision down this AirPod's belly using an ultrasonic
scalpelknife, slicing the shell without damaging the battery underneath ... mostly. -
Flex cables, antennas, and microphones are all carefully folded together like origami and cemented in place with glue. We cut away as much of the outer casing as we dare, and painstakingly scoop out the rest with a fine dental pick.
Our badges say Teardown Engineer, but today we feel more like surgeons, or paleontologists. Paleosurgeons?
With these delicate fossils extracted, it's time to examine the brains:
Apple 343S00289 (likely Apple's new H1 chip)
Dialog Semiconductor (Formerly Adesto) AT25SL128 128 Mb serial flash memory
Apple 338S00420 (likely a low-power stereo audio codec)
T 8 36 (likely STMicroelectronics inertial sensor)
Bosch Sensortec BMA280 3-axis accelerometer (likely)
Turning our attention to the brawn, we find the familiar 93 milliwatt hour battery in each bud.
We learned last time around that the AirPods case is a tough nut to crack, so this time (with some guidance from a community member) we turn to something with a bit more clamping force.
The vise deforms the outer shell just enough for us to wedge a blade into the seam, slicing through the adhesive underneath and freeing up the AirPod docking tubes.
Next, we spudger away the status LED, which is nestled between the AirPod tubes at the front of the case.
This machined metal hinge looks sturdier compared to the last generation's, and it definitely has the adhesive to match.
We go for the battery next, but the battery's adhesive has other ideas. Against our better judgement, we crank the heat to eleven, watch for swelling, and cross our fingers that the battery doesn't go Galaxy Note 7 on us.
Despite the effort, one spudger still can't lever this battery out. Fortunately, we found some more.
As the battery comes free, it's clear there is simply no comparison between this battery and its predecessor ... because they are exactly the same.
Model A1596—running at 3.81 V and 398 mAh, for 1.52 Wh.
We're starting to see a trend here. Getting the next layer out of this case requires—you guessed it—heaps of heat, a plethora of prying, and a pair of pliers.
We immediately notice that this generation's logic board is more ... goopier ... than the board that emerged from the wreckage of the first AirPod fiasco—probably to help with water resistance.
Finally, a beacon in the darkness—there's still a modular charging port!
... although if you tunnel this far into the case, there's a good chance you now have more broken parts than just the charging port.
Beneath that shiny liquid-resistant coating, we make out some chips:
Broadcom BCM59356A2KUBG wireless charging module
STMicroelectronics STM32L476MG 32-Bit ARM Cortex-M4 microcontroller w/ 1 Mb flash
TI 87A6FP
Reaching into the almost-empty case, we fish out the slightly modified (compared to last time) sync button—now with two additional solder points for the ends of the wireless charging coil.
Finally, the thing we came all this way for: the new wireless charging coil, and a thermal pad to keep it cool under pressure.
... which, despite our best efforts, refuses to come out intact.
Teardown complete! Let's put these back together and sync them up for some tunes.
Just kidding! These are toast.
That said, the construction isn't entirely unimproved—this set might survive an extra trip through the washing machine. It's just, we know Apple can do better.
If you like wallpapers, here are some bonus X-rays you can print out and skin your AirPods case with!
- AirPods are not designed to be serviced. No hardware components can be accessed without damage to the device.
- Sealed-in batteries limit the AirPods' lifespan, making them a consumable/disposable item.
Considerações finais
Índice de reparabilidade
(10 é o mais fácil de reparar)
21 comentários
That shiny water repellent coating looks like conformal coating. Does helps but only to a certain degree.
Love the tear-down but could you also delve into the top magnets that pull/hold the airpods in their charging tube and also how they are magnetically aligned in the lid? My thoughts are that the rear lid magnets oppose each other so has to help hold the lid open but their opposing force is overcome when the front magnets are attracted and obviously have more leverage being further from the hinge to snap shut and hold the lid closed. To me, this is an ingeniously overlooked design aspect of the case using magnets rather than springs to create a spring-like effect.
You guessed correctly :) That’s exactly what’s happening.
Yeah, this is important. You can sort of see it here, but it’s covered up by some type of grill.
If you check the dates on the serial numbers of the “New AirPods” you will find that they were going to be released with the iPhone Xs. Really Apple?
The hinge is on the same side as the charging coil… Anyone with a wireless charger should know metallic objects in proximity of the coil is a big no no… Change in hinge material/size mamy be also to prevent the hinge from heating while the case is charging
Vielen Dank an Annika und Sandra für ihre Übersetzung
Danke dir! Haben wir gern gemacht!
If one is trying to replace the battery rather than do a full dissection, might that be possible by making two cuts all the way through the tubes— one just above the battery and one just below, severing only the connections to the battery, antennas, and whatever is below it (a mic?).
The x-ray, were it less oblique, might show how many conductors are involved, but maybe it’d be possible to cleanly chop those tubes such that the battery is removed, then replace it with a new battery, reconnect the antennas and mic, and continue to use the AirPods for a couple more years with a new battery?
Or maybe there’s a bigger bundle of wires running through there or there’s too much glop and I’m just dreaming.
The Black Tape like thing, connecting the Speaker side to the main, what are they called. I tried to open mine, and have detached it from the middle. Can i like solder it or something ?
That is a flex cable. It’s a flexible plastic film carrying very thin wires within. Unfortunately, you can’t fix it by soldering.
has anyone checked if there are the same parts in both airpods?
My right airpod stopped playing sound a few months ago. I decided finally to say “whats it gonna hurt at this point?” and pried open the buds top with a FINGERNAIL, got my finger between the crack and slid across, broke up the glue a bit and was able to open it like a clamshell. I then proceeded to gently slip a tweezer tip between the driver and the top part of the bud, successfully revealing the driver and the underside of the mesh. I was playing music at the time so I covered the sensors and had a listen and it was playing loud and clear. I then pushed the driver back into place (removing a bit of glue that was in the way) and snapped the top back on to the stem. They come apart just like the earbuds. While I dont have the glue to keep it together permanently, I believe the friction will just be enough. It doesnt move around at all and ive already dropped it a couple times without issue. They continue to sound great now that ive done this. Nothing was damaged in the process aside from said glue.
Really enjoy the teardowns! would be great to know what drivers/coils they are using!
What the brand of the battery?
Die dauernde Werbung für Galaxy Buds im Text nervt.
