Pular para o conteúdo principal
Ferramentas utilizadas neste teardown
Introdução
This teardown is a working Actiontec Q1000 Modem, sold by Qwest as a Qwest Q1000.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Actiontec Q1000 DSL Modem, use o nosso manual de serviço.
  1. The Qwest Q1000 modem, made by Actiontec. Port side with antennas detached. DSL and Phone in ports
    • The Qwest Q1000 modem, made by Actiontec.
    • Port side with antennas detached.
    • DSL and Phone in ports
    • 4 Ethernet ports
    • USB port, reset button, and power jack
    • Not a screw in sight.
  2. As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws!
    • As usual, the rubber feet are hiding screws!
  3. Nothing really to see here... Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board. The circuit board is finally free!
    • Nothing really to see here...
    • Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board.
    • The circuit board is finally free!
  4. Looks like someone was generous with the thermal paste. Underneath the cover:
    • Looks like someone was generous with the thermal paste.
    • Underneath the cover:
    • Broadcom BCM6366
    • Broadcom BCM53115
  5. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  6. The Wi-Fi card lets down its shield... The chip is a BCM4322.
    • The Wi-Fi card lets down its shield...
    • The chip is a BCM4322.
  7. The inside of the top case. The antenna connectors are screwed onto the case.
    • The inside of the top case.
    • The antenna connectors are screwed onto the case.
  8. The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors. What's underneath the heat-shrink? A ferrite bead to minimize interference.
    • The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors.
    • What's underneath the heat-shrink? A ferrite bead to minimize interference.
  9. Testing out the light pipe with an LED throwie... The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel. Here are all the LEDS:
    • Testing out the light pipe with an LED throwie...
    • The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
    • Here are all the LEDS:
    • 8 of the LEDS that work with the light pipe
    • One more surface mount LED
    • A white LED for illuminating the Qwest logo
    • A dual-color (red/green) LED for the WPS status indicator.
  10. The empty shell that once held a DSL modem. The 2 detachable Wi-Fi antennas. Nothing to tear down here! The 2 detachable Wi-Fi antennas. Nothing to tear down here!
    • The empty shell that once held a DSL modem.
    • The 2 detachable Wi-Fi antennas. Nothing to tear down here!
  11. Repairability score: 8/10
    • Repairability score: 8/10
    • The entire device is held together with only 4 screws.
    • The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
    • The antennas are replaceable as well.
    • The heat sink is soldered in place, making removal difficult.
    • The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
Documentos anexados
jrw01
Membro desde: 22-08-2013
1.215 reputação
23 Guias de autoria
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - Responder
What are the part number, volts, and amps of the power supply?
PDXTek - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Todo: 5,744
