O que você precisa
Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
Assemble Unit in reverse order.
