Introdução
ASUS ZenPad S8 is world first tablet which has independent high-end TV level video display processor inside. Let's find out where the processor is.
The double ribbon cable of the digitizer. Is it 28mm or 26mm. I've seen both for sale. I need to buy one and don't want the wrong one.
Hi! I have a cracked screen and am looking on eBay for replacements. Most sellers only have one part, but a couple sellers have two digitizer/screen variants with the difference being the width of the connector cable. Does anyone know how to determine if there actually are two variants and if so, how to know which to order? Thanks in advance.
I don't know LCDs, but there are two models -
ASUS ZenPad 8.0 S - P01MA Z580CA - has active pen support and USB-C socket
https://en.wikipedia.org/wiki/USB#USB-C
ASUS ZenPad 8.0 S - P01M Z580C - no active pen support and Micro-USB-B socket
https://en.wikipedia.org/wiki/USB#Micro_...
I'm guessing the Z580CA has extra wires on the connector for the pen support.
Does this help?
15 comentários
Step 4 , Green color highlighted part cannot be Intel atom cpu, it should be PMU
It's hated too tell from your guide, but is it possible too replace the battery?
I have the Asus S 8 and it too has a cracked screen. I found this video on youtube.com where a guy replaces the glass screen on an Asus Transformer. He does mention two "ribbons" inside with numbers on them and says you should look at that to order the right screen, Right now, I'm trying to find a seller with the right glass. The digitizer is okay, it is only the glass which is cracked, it still works.
https://www.youtube.com/watch?v=kmN_pDAF... is the video showing his repair.
Regards,
chita.jing@gmail.com
There are 2 sizes. 28mm and 26mm. If the number on the ribbon ends in 05 it's 28mm. If it ends in 06 it's 26mm. Hope this helps. It did when I fixed mine. Now if I can find a good rear housing cover for it I'll be set. Good luck.
How do you remove the ribbon connectors? I was thinking its the unlockable lift but its too small to tell it doesn't seem to move.
See https://www.youtube.com/watch?v=kmN_pDAF... for his technique to remove ribbon.
Hello, how can i fix an asus zenpad c7 that doesnt want to turn on, it seems that its been drained its battery dead but i cant charge it. It was dropped by kids so many times. I can hear and feel its vibrating when i pressed the on/off button but screen doesnt show anything. Any help please.
I sent it 1 time to seevice center and they said the relay was dislodged and battery was drained dead. Thanks in advance.
Can anyone offer a suggestion as to a good replacement battery source... and part number?
I need to replace the usb charging port on mine, any suggestions?
My ASUS Zen pad does not recognize the camera. The message says it is not installed. Please suggest a solution. Os it software that needs to be upgraded or the camera to be replaced. The device is new
My ASUS Zen pad will not recognize the camera. The message says “camera not found”. Is this a software problem or is the camera defective and needs replacement. Please advise. If it is software problem please advise steps to correct it. Thasnks
Good evening. I love this tablet and unfortunately, two months after my warranty expired, the charge port stopped working.
When I look inside I can see that one of the pins is somewhat loose, seems like the plastic bit is also broken somehow. A couple weeks ago my tablet stopped charging, but it would still charge when it was off. This morning I tried doing it as usual, but the micro USB cable wouldn't even enter. Is there any temp fix for this or do I have to replace the port? In case I have to replace it, would the fix be easy? I can solder small stuff as long as it's not too complex.
how to buy charging USB Jack Board For Asus ZenPad S8.0 Z580CA USB Charger
Ciao, devo cambiare la scheda madre, perché non si riavvia più e non viene riconosciuta dal PC. Come posso fare per averla con ram più alta e memoria più alta.?
Hi, I have to change the motherboard, because it no longer restarts and is not recognized by the PC. How can I have it with higher ram and higher memory?
