Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua A.C.Ryan PlayOn!HD, use o nosso manual de serviço.
  1. A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: passo 1, imagem 1 %32 A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: passo 1, imagem 2 %32
    • The ACRyan PlayOn HD with remote control.
  2. A.C.Ryan PlayOn!HD Teardown: passo 2, imagem 1 %32 A.C.Ryan PlayOn!HD Teardown: passo 2, imagem 2 %32
    • The rear panel with the necessary connectors.
  3. A.C.Ryan PlayOn!HD Teardown: passo 3, imagem 1 %32 A.C.Ryan PlayOn!HD Teardown: passo 3, imagem 2 %32
    • The location of the 2.5 HD is at the bottom of the case.
  4. A.C.Ryan PlayOn!HD Teardown: passo 4, imagem 1 %32 A.C.Ryan PlayOn!HD Teardown: passo 4, imagem 2 %32 A.C.Ryan PlayOn!HD Teardown: passo 4, imagem 3 %32
    • The small motherboard with the USB and IR receiver PCB.
Vincent Tay
Membro desde: 01/14/14
101 Reputação
Autoria de 1 guia
4 comentários
Hi,
I have a somewhat different problem my remote broke and before I buy a new one I want to try fixing mine there are two components missing which I could easily replace but I don't know the ratings or model numbers of the components. So if anyone could send me pictures of the components that would be awesome.
mpinnie - Responder
Have you fix it? Or you had threw it away?
Bee B - Responder
Hi
the ac Ryan is not being recognised by my laptop through USB Connection.
Is there any remedy?
Cyril Kevin - Responder
Hi! Where can I buy the remote control of AC Ryan
Roberto Albino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Duração total: 3,410
