Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua A-Solar Power Bank AL-200, use o nosso manual de serviço.
  1. A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: passo 1, imagem 1 %32 A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: passo 1, imagem 2 %32
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. A-Solar PowerBank AL-200 Teardown: passo 2, imagem 1 %32 A-Solar PowerBank AL-200 Teardown: passo 2, imagem 2 %32 A-Solar PowerBank AL-200 Teardown: passo 2, imagem 3 %32
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. A-Solar PowerBank AL-200 Teardown: passo 3, imagem 1 %32 A-Solar PowerBank AL-200 Teardown: passo 3, imagem 2 %32
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  4. A-Solar PowerBank AL-200 Teardown: passo 4, imagem 1 %32
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  5. A-Solar PowerBank AL-200 Teardown: passo 5, imagem 1 %32 A-Solar PowerBank AL-200 Teardown: passo 5, imagem 2 %32
    • The other side of the electronics.
    • And the logic board.
  6. A-Solar PowerBank AL-200 Teardown: passo 6, imagem 1 %32
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
Membro desde: 07/07/12
552 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 5,235
