O que você precisa
Remove the 2 black #1 Phillips screws holding down the lamp cover, then remove the 2 screws with arrows on the lamp.
Remove the t-10 torx screw on the top of the lamp, and then the phillips screw holding the power connector down.
Remove the screws holding down the bracket for the lamp bulb, then remove both the bracket and the bulb.
Remove the screws holding both the large metal piece to the base and the smaller metal pieces onto the larger one. You can then remove everything.
Remove all the Phillips screws holding down the metal shield around the ports.
Remove all phillips screws from the back and bottom of the projector. Fortunately, none are hidden.
See Step 6 for more details.
Carefully lift the cover off of the projector as pictured. Unplug all the connectors you can reach whichever way you desire.
Set the projector cover towards the front and unplug any remaining connectors until the cover is free.
Simply pull the fans out from the side of the projector and unplug them. They are contained in rubber bumpers.
Remove all phillips screws holding the I/O board and power connector on. Push the power plug to the side and remove the I/O board.
Remove the screws holding down the mainboard and lift it off the metal frame.
The top and bottom of the boards are here for reference.
Remove the screws holding down the metal frame and remove it from the case.
Pull the gray trim piece out from next to the frame and set it aside.
Remove the phillips screws from the sides of the box containing the power supply. You can now lift out the power supply.
Push up the insulating sheet, then remove the screws holding the board to the metal case. The board is now free.
Repeat on the other side of the power supply.
Remove any remaining screws holding down any metal pieces, including the main projector lens, and remove it.
I won't go into too much detail here, but to disassemble the main unit, unscrew the screws, remove the parts or brackets that they're holding in, and repeat.
