Meu Problema
Purchased the MBP with a small SSD with intentions to implement this configuration
Minha Solução
Relatively smooth. I would recommend using a Phillips #0 rather than #00
Meu Conselho
Be absolutely certain the SSD you wish to install has a compatible data transfer rate with your machine AND has the most up to date firmware (TRIM enabled)
0 comentários
