Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
« Voltar para Todas as Histórias
2010 Mac mini optical drive replacement and harddrive upgrade.
rylander -
Meu Problema
The optical drive had failed and I wished to replace the stock harddrive with a solid state drive.
Minha Solução
Perfectly. It was not nearly as difficult as it first appeared, but I certainly could not have done it without the guide, nor without the tools.
Meu Conselho
Removal of the power supply requires that one lift slightly the tab through which its fastening screw passes. I had a heck of time getting the power supply to slide out until a realized this.
Imagem de Illuminated Magnifier Table Lamp
$29.99
Imagem de Mac mini Logic Board Removal Tool
Imagem de Pro Tech Toolkit
Pro Tech Toolkit
$69.99
Adicione um comentário
