« Voltar para Todas as Histórias
Trial and Error!
xandelguzman -
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement
30 minutos
Easy
Meu Problema
My computer was unresponsive, rainbow wheel and not working at all... So i tried changing the RAM which did nothing. I changed the Hard Drive and it didn't work either. Finally i decided that the cable between the hard drive and the logic board must be defective... so i got a friend that has the same macbook pro as me an changed his cable for mine and the computer worked flawlessly.
Minha Solução
15 minutes tops to repair... very easy. Decided not to use the adhesive tape because if i messed up the position i could have had a very hard time trying to repair it.
Meu Conselho
Follow instructions to the letter. Small screwdriver with magnetized point.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable Imagem
$44.99
