Meu Problema
The problem was YLOD couldn't use it and didn't
Want to send it off and besides the feeling
Of accomplishment is Great!!!!!
Minha Solução
I screwed up right from the start,I pulled down on the
Switch on the heat gun and started the repair,I went
Through the steps heating and finished before I checked
And saw I was using high heat instead of low heat,so I
Had to wait for quite a bit longer for the system to cool
Down.bottom line it works better than ever I am so glad
I chose to do it myself,Thank you.
Meu Conselho
Follow directions,check and make sure you
Are using low heat and happy fixing it yourself!!
0 comentários
