Ir para o conteúdo principal
« Voltar para Todas as Histórias
Easy to replace: a MacBook's right fan
Marnix -
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement
Moderate
Meu Problema
I had a noisy right fan, my MacBook sounded like a diesel engine. And well, it didn't cool any longer, I noticed my MacBook getting hot during charging the battery and using the computer.
Minha Solução
The repair was really easily done. The only tricky thing was: it appeared that the front, when gently lifted, still is attached to the main board by a sensor that is placed under the left speaker. So, you can't turn the front up as the hood of a car, as shown in the guide, I had to turn it away to the left gently.
And man, the connecters are tiny! Took me a while to figure how to disconnect the old fan.
Still, it's an easy job to do.
Meu Conselho
Maybe it's a good idea to add at step 9 of the guide "how to disconnect the sensor under the left speaker".
Imagem de Spudger
Spudger
$3.99
Imagem de T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Imagem de Phillips #00 Screwdriver
$5.49
0 comentários
Adicione um comentário
