Pular para o conteúdo principal
« Voltar para Todas as Histórias
Peace and quiet return
kjwolff8891 -
MacBook Unibody Model A1278
MacBook Unibody Model A1278 Fan Replacement
5 - 10 minutos
Easy
Meu Problema
The old fan had become noisy - bearings worn out probably. (After taking it out, I could see the blades spun crooked.)
Minha Solução
Pretty easy repair, only 3 internal screws. The connector is a little tricky since it's so small, you tend to think you're gonna break it. Go slowly around the edges and it'll come out.
Meu Conselho
I'll second something someone else said about the new fan seeming much higher quality - spins much easier, though it seems to be exactly the same part. Could be just that the old one was, in fact, screwed up, and it once spun the way the new one does.
Unibody 8x SATA SuperDrive (Pre-Mid 2009) Imagem
$49.99
Adicionar comentário
