Ir para o conteúdo principal
« Voltar para Todas as Histórias
Original iPod Touch battery replacement.
bhdent -
iPod Touch 1st Generation
iPod Touch 1st Generation Battery Replacement
30 minutos - 2 horas
Very difficult
Meu Problema
When the Touch was placed on the charger, the display indicated a red band at the base of the batter icon, and an indication of <20% of charge. After one hour of "charging", the red band had NOT moved. Usually one would expect that the red band would migrate to a green band that expands to full battery charge.
Minha Solução
Haven't done it yet! But I will report the results of my work when completed.
I'm sort of miss using your feedback column to complement your iFixit Group on what a Really Top Notch business you are running.
I too am a Poly grad (class of 67) in electronic engineering. Retired about a year ago from 25 years with AT&T.
I found your web site about a year ago, and was amused by the clever idea of a "Fixit Web Site". I now see that your business is a going concern with one of the best web sites I have ever seen.
Your "fixit guides" with the video, and the parts and tools support is second to none. I don't believe I have ever seen a more comprehensive well organized web site, and order processing system. Although you are in a different business than Amazon, I would say your customer service interface and followup is of the highest quality. Thank you and keep up the
the good work. Your web site and product is a high quality example of what Poly can produce. bhdent @ hotmail.com
Meu Conselho
Not yet! But if I have any, I will happy to share.
Imagem de Pro Tech Toolkit
Pro Tech Toolkit
$74.95
0 comentários
Adicione um comentário
