« Voltar para Todas as Histórias
MacBook Pro 13" Mid 2010 Drive problems
jeff -
MacBook Pro 13" Unibody Mid 2009
MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement
30 minutos
Easy
Meu Problema
The drive appeared to be failing with lots of beachballing. Took the drive out to connect it via an external carrier to another Mac and it worked perfectly. So I knew it was the controller or cable. Googled and for some reason this is a common problem. I'd love to know why?
Minha Solução
Easy. 5 minutes.
Meu Conselho
If you have drive failure symptoms on your MacBook Pro, check the cable first.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable Imagem
$44.99
