Ir para o conteúdo principal
« Voltar para Todas as Histórias
MacBook Pro 17 sounds like a leafblower
drew -
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan Replacement
Moderate
Meu Problema
At least one of the fans in my unibody MacBook Pro 17 was making pretty horrific noises. I've had this happen before in MacBook Pro systems. The poor little fans give their all and then die.
Minha Solução
I replaced both fans just to be sure, it took about 2 minutes to get the case open, and about 2 minutes each to swap the fans. I had to open the machine up a second time since one of the fans had a small rattle to it. It turned out the replacement fan had been compressed slightly in shipping. I quick tweak to the fan, reinstall it, and the machine is back running and happy. I was selling it, so it is now on it's way to Georgia to live out it's years running Qlab in a theme park.
Meu Conselho
If your fans are noisy, do the replacement yourself. It should take less than 10 minutes, and it's dead simple.
Imagem de MacBook Pro 15" Unibody (2.53 GHz Mid 2009) or 17" Unibody (Early/Mid 2009) Right Fan
$21.99
Imagem de MacBook Pro 17" Unibody (Early-Mid 2009) Left Fan
$34.99
0 comentários
Adicione um comentário
