Ir para o conteúdo principal
« Voltar para Todas as Histórias
Easy Fix for an Old but Useable Laptop
Joshua Nelson -
Lenovo ThinkPad P1 Gen2 Laptop
Imagem da história
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
20 minutos
Easy
Meu Problema
I have a Thinkpad P1 Gen 1. It is about six years old at this point, but still works great (other than the battery!). Note: this battery works for the Gen 1, too.
Minha Solução
All was super smooth and corresponded to iFixIt's guide. There are a few screws in the back of the case, four that hold the battery in, and a small connector. Everything can be done with a small Phillips screwdriver.
Meu Conselho
1) Even though iFixIt says this battery is not compatible with the P1 Gen 1, I can confirm that it is (at least with my model of laptop). I checked before ordering: the Model Name and Part Number are exactly the same. The connector and dimensions are all perfect.
2) There are two electrical things to watch: first, the connector to the battery must be slid a bit to the left while disconnecting. Second, there are red & black wires at the bottom of the battery (for one of the speakers) that are routed between tabs of the battery casing. Remove these carefully when removing the old battery & carefully replace them on the new one.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 320
