Ir para o conteúdo principal
« Voltar para Todas as Histórias
Fixed a Client’s AC – Common Issue with a Simple Solution
Aqua Cool Point -
Imagem da história
Meu Problema
Recently, I received a service call from a client whose RO water purifier had stopped working properly. The water flow had slowed down significantly, and the taste of the water had changed.
Minha Solução
Started by disconnecting the power and water supply to ensure safety.
Removed the filters and found the pre-filter was completely choked with dirt and sediment.
Checked the RO membrane – it was heavily clogged and had passed its lifespan.
Replaced the pre-filter, carbon filter, and RO membrane with new ones.
Cleaned the storage tank and sanitized the system before reassembling.
Meu Conselho
Never delay filter replacement — it can damage the RO membrane.
Avoid using non-compatible parts or cheap filters, as they affect water quality and system life.
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 140
