Ir para o conteúdo principal
« Voltar para Todas as Histórias
Cat's teeth vs iPhone Lightning Cable :)
in_sympathy -
Imagem da história
  • Imagem nº 1
  • Imagem nº 2
  • Imagem nº 3
Meu Problema
Cats destroyed mom's iPhone charging cable, so she was no longer able to charge her devices at home. Asked me to buy her a new cable, but it's no fun - I decided to rather have it repaired, since I had quite a few spare lightning connectors.
Minha Solução
Without a microscope this repair is only doable with a good flux and during a daylight, because despite wires and connectors are not being literally microscopic - it's quite difficult so solder and see if everything is done right.
Meu Conselho
Again - good flux, good solder and soldering iron is key. Also I suggest starting with Data+ and Data- wires in the middle and then soldering V and G on the sides.
Imagem de Soldering Station Hakko FX888D-23BY
$122.99
Um comentário
Great information. Thank you for sharing.
Taylor Ryan - Responder
Adicione um comentário
