BATTERY REPLACEMENT - MACBOOK 15" RETINA
Meu Problema
Unless the Macbook was on the adapter, it went to sleep mode within 20 minutes. Battery needed to be replaced.
Minha Solução
The repair time estimate of 2 hours was almost on the mark. However, it took almost another hour to remove the adhesive from the old battery.
Meu Conselho
Buy the magnetic pad. You can label the screws by step and pieces. Also, I said earlier that the repair took almost another hour to remove the adhesive from the old battery.
0 comentários
