Ir para o conteúdo principal
« Voltar para Todas as Histórias
Macbook Pro Battery Replacement
Kian Keong Tan -
Imagem da história
Meu Problema
Battery is dead.
Minha Solução
Successfully replaced the battery with a new one.
Meu Conselho
Don't be too quick to come to a conclusion of the battery is dead when you realized that the battery is not charging at the MacOS desktop. After I changed the battery with a new one the status remained the same. Which I then realized al the while, it was the charging curcuit of the mainboard failed.
The tell-tale sign that the charging curcuit having issue is when you noticed the Macsafe cable charging light is not turning on.
Imagem de Pro Tech Toolkit
Pro Tech Toolkit
$79.95
1 comentário
Press F to pay respects.
nietsniE treblA - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 425
