Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
« Voltar para Todas as Histórias
Incredibly Easy
Paulette Morgan -
Kindle Fire HD 8.9"
Kindle Fire HD 8.9" Headphone Input Replacement
10 minutos
Easy
Meu Problema
I broke a headphone jack off in the Kindle
Minha Solução
A co-worker of mine actually did the repair. He said the step-by-step instructions and photos made this repair so easy.
Meu Conselho
Get the screwdriver, the tool to open the Kindle, the instructions and an extra set of hands. I opted to not separate the top from the bottom (left the flex cable attached) . Instead, I held the bottom at a 90 degree angle while the top was laying flat. Ric took out the 2 screws holding the piece in, removed the old audio jack, replaced it with the new jack, screwed it back in and carefully aligned the side with the flex cables and snapped it back together. The instructions and the extra set of hands was the key to replace the audio jack.
Imagem de Phillips #0 Screwdriver
$5.49
I bought a new Kindle because I kept running into problems trying to find a repair shop that worked on Kindles'.
Paulette Morgan - Responder
Adicione um comentário
