Meu Problema
System was showing an Error code displaying that the SD card couldn't be read
Minha Solução
Repairing part was easy. After taking off the back plate, you have to detach the trigger buttons from the logic board and after that, the microSDHC reader pulls out of the board with just a little tension (similar to removing Headphones from a media player). The replacement part slides in just as easy
Meu Conselho
Check the MicroSD card before replacing the part. My SDHC card was unreadable so I needed to buy a new SD card anyway. If the Error message still shows up after you replace the SD card and/or SD card reader, the problem may be with the logic board
Um comentário
Hey I know this is very but I’m a bit of a Techno noob but this has happened to me as well and I’m getting a new micro SD card slot do you just plug the thing into where the original one was?
Evans Stokes - Responder
