iPhone 6 Lightning Charging port replacement and battery replacement.
Meu Problema
My lightning connector charging port was loose and I had extreme trouble charging my phone. I know when inside the phone I needed to go ahead and change out my battery also.
Minha Solução
Repair went great, all went as planned until I got to removing the battery which proves to be fairly difficult with the adhesive strips.
Meu Conselho
To remove the battery, I had to use a blow dryer on the back of the case to soften the adhesive strips. Then I used a string and gradually worked it back and forth under the battery until the strips were free. Other than than, the repair went smoothly.
0 comentários
