Ir para o conteúdo principal
« Voltar para Todas as Histórias
MacBook Air battery replacement
Marshall Barnett -
MacBook Air 13" Mid 2011
MacBook Air 13" Mid 2011 Battery Replacement
15 minutos
Easy
Meu Problema
4-year old battery no longer holding a charge for more than 1-1.5 hour.
Minha Solução
Overall very easy. The guide is very helpful and high quality tools ordered from iFixit helped tremendously.
Meu Conselho
The only tough part was reconnecting the battery terminal once the new battery is in place. The cables were a bit rigid, so it was tough to line it up perfectly. Helped to lift the battery out slightly, then connect the cable and place the battery in the slot where it belonged.
Imagem de T5 Torx Screwdriver
T5 Torx Screwdriver
$5.49
0 comentários
Adicione um comentário
