Ir para o conteúdo principal
« Voltar para Todas as Histórias
Installing SSD on iMac Intel 27" Mid 2011 Model replacing the optical drive
Dennis Luzon -
iMac Intel 27" EMC 2429
Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
1 hora
Moderate
Meu Problema
I just need to speed up the read and write speed of the disk, installing and using a second hard drive such as SSD will do the job.
Minha Solução
Taking out the optical drive and replacing it with an SSD went well just having some difficulty in putting back the logic board it took me a while to insert in back in the right spot.
Meu Conselho
Upon replacing the optical drive to an SSD and using the SSD as the main OSX home. Start up processing time went up by almost 10 times faster than before(using installed HDD).
The only set back for me is the noise level that is coming out from the fan dedicated for the optical drive.
Is there a way to lessen the noise level? Do I have to disconnect the fan at all?
Imagem de iMac Intel 27" (Mid 2011) Dual Hard Drive Kit
$27.99
0 comentários
Adicione um comentário
