Meu Problema
Original digitizer was broken\leaking internally
Minha Solução
Display assembly was fairly simple to replace. Only complaint is now the back panel doesn't snap in all the way near the aux port, even after triple checking everything. Good thing my case covers it :)
Meu Conselho
Make sure to check all the antenna connections. Had an issue with the LTE after replacing the screen. Turns out the Black & white antenna cables got disconnected after securing the midframe piece
0 comentários
