Pular para o conteúdo principal
« Voltar para Todas as Histórias
Standard battery & pentalobe screw replacement
richfvee -
iPhone 4
iPhone 4 Battery Replacement
5 - 30 minutos
Moderate
Meu Problema
Nothing dramatic - the battery has always been a dud.
Minha Solução
It went great! Although, the screwdriver for the Phillips screws doesn't quite have enough bite into the screws, so it slips a lot. It may just be because the screws are so small.
Meu Conselho
The instructions should mention that you need to bend the battery connector flat cable so that it is similar to the one you pulled out. Easy to figure out, but I can imagine some people having problems. Also, it might be good to include some small plastic tweezers in a kit.
I'm very happy with iFixit's parts & especially the instructions/videos. As a Cal Poly SLO grad, I'm proud of you guys! Thanks for a great service. I'll be back soon for a home button...
iPhone 4 Replacement Battery Imagem
$14.99
iPhone 4/4S Liberation Kit Imagem
$9.99
Adicionar comentário
