Replace a swollen, old battery
Meu Problema
The old battery had swollen enough to push on the trackpad.
Minha Solução
The repair went exactly as advertised!
Meu Conselho
Because the old battery was swollen, it pushed against the bottom case panel with enough force to throw the tiny screws some distance as I loosened them! If your old battery is swollen, take care to apply some pressure to the bottom panel and contain the screw you're removing until you've completely removed the screw.
0 comentários
