Pular para o conteúdo principal
« Voltar para Todas as Histórias
Repair went well, not all steps required.
lambdahindiii -
iPhone 5s
How to replace the battery in your iPhone 5s
30 minutos - 1 hora
Moderate
Meu Problema
Original battery was dying so I put in a new one.
Minha Solução
It went well! Took me about 40-60 minutes in total. The old battery was VERY difficult to remove and I ended up destroying it in the process.
Meu Conselho
I skipped steps 11-16 and that worked pretty well from me. On another commenter's advice, I simply used some packaging tape to tape onto the top of the screen, over the top of the phone, and onto the back of the phone to hold the display at a right angle to the rest of the device. Saved me all the trouble/risk of disconnecting the display, but if you use this method you should be VERY careful not to hit the display while removing the battery .
iPhone 5s Replacement Battery Imagem
$29.99
Adicionar comentário
