Ir para o conteúdo principal
« Voltar para Todas as Histórias
Almost Made it!
yarbroughba -
iPod 3rd Generation
iPod 3rd Generation Battery Replacement
45 minutos
Moderate
Meu Problema
Battery Replacement in 3rd Generation iPod
Minha Solução
Replaced the battery with no issue and the tools worked great. The batter wires were a little longer so they wouldn't thread around the logic board. I encountered two additional issues after replacing the battery. 1. The pins for the headphone jack pulled out of the plug and were bent. Make sure you are very careful when opening the case!! 2. When I tried to charge the battery, the iPod would not recognize the plug and the battery did not change. I guess one problem down and now two more to go!
Meu Conselho
when opening the case, if easier, you can work the small opener around the opposite direction from the instructions. Worked easier for me.
Imagem de Spudger
Spudger
$3.99
Imagem de T6 Torx Screwdriver
T6 Torx Screwdriver
$9.99
Imagem de iFixit Opening Tool
iFixit Opening Tool
$1.99
Imagem de iPod 3G Battery
iPod 3G Battery
$18.99
0 comentários
Adicione um comentário
