Ir para o conteúdo principal
« Voltar para Todas as Histórias
Rescue a drowned iPhone
calvinchestnut -
iPhone 5s
Imagem da história
  • Imagem #1
  • Imagem #2
  • Imagem #3
How to replace the battery in your iPhone 5s
30 minutos - 1 hora
Moderate
Meu Problema
My cousin decided to take his phone swimming with him at a water park. Since it was in a Lifeproof case he thought it would be fine to keep in his pocket for ~30 minutes while in the water, so it was more or less completely submerged. The usual tricks (rice, leave alone for a few days) did nothing to help, so he got a replacement through his parent's insurance and left the soaked phone for me.
Minha Solução
The repair went fine. The iSclack was fantastic. I couldn't recommend it enough. If you think there's any chance you'll have to open up an iPhone 5/S/C more than once it's a worthy investment. No prying, no tricks. It's a bit scary when you're pressing the handle down and suddenly the screen snaps off, but after ~10 openings there has been no damage or problems.
I got the battery for the 5S mostly to get the tools to open the phone, and also because I figured that would be the least of the problems. Sure enough there was a lot of corrosion damage on the logic board and on the display connectors. The Speaker and front facing camera connectors were totally fried. I plugged in the new battery and nothing happened, so I decided to follow a different tutorial on cleaning water damage (Repairing iPhone Liquid Damage).
I only had 75% alcohol, but I cleaned up the corrosion with a q-tip and let the logic board soak for ~30 minutes and dry for 1.5 hours under a fan. When I put everything back together and plugged in the battery nothing happened, but when I plugged the phone in to power I heard the charge noise! It was showing up in iTunes, and I was able to restore the phone. Unfortunately the screen still wasn't working. I used a spare, broken iPhone 5S display to verify that it wasn't a problem with the logic board. It was really exciting knowing that I was able to bring this phone back to life. And then I broke everything again.
I tried taking apart the display to clean up the corrosion on those components as well, and I located some more corrosion on the Logic Board. So a bit more alcohol, and I let the log board soak again. This time I got impatient and only waited ~30 minutes after taking it out of the alcohol and drying under a fan to try putting it back together. I don't know if the alcohol was still present in the battery connector or what, but when I plugged in the battery and Lightning port to the logic board the speaker started making a static noise. It would stop if I disconnected either component, but I couldn't get it to show up in iTunes any more. After a couple minutes the static noise died, and I haven't gotten a peep from the device since. I let it dry for 3 days and tried putting it back together this morning, to no luck.
Meu Conselho
Main lesson, once you've identified the problem component focus on that. I shouldn't have messed with the Logic Board after I verified that I had fixed the original problem.
Also, once I got it powered on the 'charger connected' noise played on a 5 second loop as long as it was connected to power. If unconnected it would not power on. There was no conclusive explanation I could find online, but I was able to verify that this is an indication that the phone isn't recognizing a usable LCD. I unplugged the LCD from my iPhone 5, which is in perfect working order, and didn't plug it in properly and it was giving the exact same noise.
Imagem de iPhone 5s Battery
iPhone 5s Battery
$29.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 108
