iMac Opening Wheel
  • iMac Opening Wheel / Complete Tool / New  / Individual
  • iMac Opening Wheel / Replacement Wheels / New  / 5
  • 360°
360
iMac Opening Wheel
US$7,99
US$7,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
It's like opening an iMac pizza
  • The unique design of recent iMac models requires the cutting of the foam tape on the display to get inside.
  • This tool comes in two parts:
    • The handle is made of reinforced nylon and easily accommodates the cutting wheel while providing plenty of grip. In addition, the back of the handle features a thin prying and slicing blade to ensure you loosen all the adhesive.
    • The cutting wheel is specifically designed to slip in the hair-thin gap between the display and the aluminum frame, then easily cut the foam holding the two pieces together.
Compatibilidade
iMac 27" 2017
EMC 3070 3.4 GHz
EMC 3070 3.5 GHz
EMC 3070 3.8 GHz
EMC 3070 4.2 GHz
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Late 2015)
2.8 GHz (Late 2015)
iMac Intel 21.5" EMC 3068
EMC 3068 non 4K 2.3 GHz
iMac Intel 21.5" Retina 4K Display (2015)
EMC 2833 3.1 GHz
EMC 2833 3.3 GHz
iMac Intel 21.5" Retina 4K Display (2017)
EMC 3069 3.0 GHz
EMC 3069 3.4 GHz
EMC 3069 3.6 GHz
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5k Display
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
EMC 2834 3.2 GHz (Late 2015)
EMC 2834 3.3 GHz (Late 2015)
EMC 2834 4.0 GHz (Late 2015)
iMac Pro
EMC 3144 2.3 GHz (Late 2017)
EMC 3144 2.5 GHz (Late 2017)
EMC 3144 3.0 GHz (Late 2017)
EMC 3144 3.2 GHz (Late 2017)
Mostrar mais 10 dispositivos
Histórias de Reparos
Mikel Neal's Story Photo #1419075
Mikel Neal's Story Photo #1419079
Mikel Neal's Story Photo #1419077
Meu Problema
Failed hard drive. Replaced with SSD.
Minha Solução
Fairly tedious. Made sure to clean any leftover adhesive from original adhesive strips with rubbing alcohol. Took my time and got the display perfectly centered.
Meu Conselho
BUY THE CUTTING TOOL FROM IFIXIT. It also helps to have a spudger to remove the original adhesive st . . .
markford's Story Photo #906768
markford's Story Photo #906767
Meu Problema
Stock hard drive too small (1Tb) and decided to install a Seagate 4Tb Fusion drive.
Minha Solução
Perfect.
Meu Conselho
Key Tips - 1. Read both the Hard Drive, Display and Adhesive Strips guides, including user comments before picking up a tool, 2. Have the correct tools, hard drive and adhesive strip kit, 3. Have patience
Meu Problema
Changing hard drive to SSD
Minha Solução
Great, The iMac Opening Wheel tool made the job so easy to get done.
Meu Conselho
Be Patient
Meu Problema
The computer had worked very slow for months so I ended up redeploying it in a hobby room. After a month it failed to boot, and recovery mode wouldn't work and First Aid failed.
Minha Solução
The replacement of the HDD and the application of the adhesive strips went EXACTLY as described (including the slip of the . . .
Meu Problema
Installed 16GB of Ram and 512GB SSD
Minha Solução
It went great, definitely take your time and keep track of where screws go
Meu Conselho
As I removed screws and did the steps, I kept the parts in zip lock bags together, which made putting it back together that much easier!
Meu Problema
Had to remove and replace Hard drive
Minha Solução
Went well, took about 2 hours.
Meu Conselho
Take your time, do not rush it. When lifting the Screen to remove connections, it was helpful to have an assistant. He held the screen up, while I unplugged those pesky connectors. Also, when removing the old adhesive strips, you can . . .
Meu Problema
Apple STUMPED - iMac shuts off randomly, daily to multiple times/hour
Minha Solução
Repair went perfectly. Time will tell if the power supply was truly the culprit in the issues I was having that Apple was UNABLE to diagnose.
Meu Conselho
You might have to run a card or spudger a few . . .
Meu Problema
Slow hard drive swapped with SSD.
Minha Solução
Touch and go for a moment cutting off the glue from the screen.
Meu Conselho
Once you are able to pry the screen apart, you are able to get to everything and re-tape back the screen
be patient and steady hands to tape back the screen and make sure you have finger nails
Meu Problema
The old HDD was really bogging down the iMac, the SSD gave it new life.
Minha Solução
Surprisingly easy. The iFixit iMac opening tool made the repair a cinch.
Meu Conselho
Have a second person that can help.
Meu Problema
I love the iMac hardware more than any other all in one that I've ever tried but the HD was sooo slow!
Minha Solução
After watching the video a coupled of times, the tools were perfect for the job and I was able to manage swapping out the hard drive in less than 40 minutes.
Meu Conselho
Watch the video until you have the confid . . .
Mostrar mais
