iFixit Opening Tool
  • iFixit Opening Tool / Individual
  • iFixit Opening Tool / 5
  • 360°
360
iFixit Opening Tool
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.
US$4,99
US$4,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
The primary tool for opening everything
  • Custom-designed handle provides no-slip opening power with plenty of grip.
  • Tough-yet-soft material prys open the tightest cracks, but won't scratch or mar your workpiece.
  • Two tips provide alternate opening options: Wedge for breaching, and Hook for lifting and levering.
  • Convenient pack of 5 tools, for 10 total prying tips!
Vídeo do Produto
Histórias de Reparos
Magnus Flovikholm Røyset's Story Photo #1445041
Magnus Flovikholm Røyset's Story Photo #1445040
Magnus Flovikholm Røyset's Story Photo #1445043
Meu Problema
A couple of months ago, my four year old iPhone 5S had a severe shutdown. It was all black, and wouldn't start until after a couple of hours connected to the charger. I panicked, thinking the phone was dead.
Luckily it booted up again, but afterwards I have had to charge my phone every night. If no . . .
Meu Problema
My battery was running out too quickly. Had to charge my phone at least 3 times during the day. The fg_fullcapnom showed the capacity to be 1145, instead of 3000mAh original capacity.
Minha Solução
YouTube was a big help. I used their complete detailed guide to replace my battery. It went perfectly well.
Howe . . .
Meu Problema
My keyboard was getting worn out and the 'm' key didn't always work which is aggravating.
Minha Solução
oldturkey03 wrote clear instructions and with good pictures. I found that the screws weren't always where they were shown but that is probably due to HP G72 manufacturing changes. The keyboard is a 'bear' to get . . .
Meu Problema
The problem is the NOOK HD...what a RIP-OFF! Barely used, yet when not in use, battery dies...after stressing on how to open this item, finally ordered tool....worked great, the tool that is...NOT the Nook...more $$$$ down the drain...#buyingbooksinstead
Minha Solução
The replacement of BRAND NEW BATTERY was the h . . .
Meu Problema
Slowing performance on my phone.
Minha Solução
Repair went well following the instructions.
Meu Conselho
I replace my battery, screen, and lightning connector. I recommend going through the guides while you wait for your parts in the mail. Remember to lay the screws out in a specific order since every group has all different si . . .
Meu Problema
Battery was old and phone wasn't holding a charge.
Minha Solução
Repair was much faster and easier than the guide and online posts. Took me 10 minutes with the standard iFixIt repair kit, which had everything needed and more. Now my iPhone battery and speed is back to normal. Great website, videos and guides!
Meu Conselho
Step . . .
Meu Problema
My iPhone 6 Plus display recently started flickering and, at times, became unresponsive unless I literally forcibly twisted the phone in order to get it to respond. This issue was extremely annoying and frustrating, especially when trying to answer a call. So, I had three choices. Buy a new iPhon . . .
Meu Problema
The top corner of my screen cracked a whole hour after I took my case off, so I decided to get in touch with my iFixit friends to get it repaired. While I was doing that, I decided to replace the battery as well.
Minha Solução
It was a piece of cake! The Repair Kit had everything I needed, and was labeled perfectl . . .
Meu Problema
My phone would need to be charged at least 2-3 times a day with moderate normal use. There were times where it would shut off completely with 50-80% battery life showing. Very hard to rely on a phone under the conditions so I purchased the battery fix kit from ifixit and could not be happy with how . . .
Meu Problema
Found an old iPod, thought it was a gonner. After a quick Google I found this website couldn't believe they had everything I needed and instruction! Anyway super easy super fast delivery and now I'm jamming like the old days.
Minha Solução
Went great really easy.
Meu Conselho
Raise your dead....devices.
Mostrar mais
