Fix Your Stuff
Right to Repair
Parts & Tools
Wire Stripper
  • Wire Stripper / Economy
  • Wire Stripper / PA-05 18-30 Gauge
  • Wire Stripper / PA-14 20-34 Gauge
Wire Stripper
US$ 5,99
US$ 5,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
The perfect tool for cutting, stripping, and crimping.
  • 10-22 Gauge Wire Stripper
  • Screw Cutter
  • Wire Cutter
When it comes to wire working, no tool is more handy than a wire stripper. These pliers feature special grooves specially designed to cut only the casing on the wire and not the metal underneath. These are absolutely a must-have for both the professional electrician and the hobbyist tinkerer.
If you're serious about wire stripping, be sure to check out our Lightweight Wire Strippers for another awesome pair of wire strippers. If you're looking to outfit yourself with a great soldering setup, check out our Soldering Workstation.
Histórias de Reparos
Avatar do usuário
Emil Wessel Melgaard's Story Photo #396546
Emil Wessel Melgaard's Story Photo #396549
Emil Wessel Melgaard's Story Photo #396548
Meu Problema
The screen on my Nexus 7 was shattered. Everything worked fine, except the touchscreen (the device was perfectly usable with an external mouse).
I am normally not clumsy, and it is the first time I have cracked a display. It happened when I tried to pick it up from a table with one hand. I lost the . . .
Avatar do usuário
Ong Beng's Story Photo #1332088
Meu Problema
Nothing
Minha Solução
Nothing
Meu Conselho
Nothing
Avatar do usuário
Meu Problema
Needed better tools for our student techs to fix our out of warranty Macs.
Minha Solução
The tools and online tutorials made the repairs quick. It also gave our students confidence.
Meu Conselho
Get students involved in your 1 to 1 program.
Avatar do usuário
Meu Problema
So I bought my macbook pro back in 2009 and i loved how i could use it for up to 5 hours in single charge while having a number of apps open. With the years of course, the battery capacity decreased, programs would load super slow, the fan would start spinning like crazy with just streaming videos o . . .
Mostrar mais
